scamp
Joined: 02 Aug 2004 Posts: 14 Location: United Kingdom Thanked: 0 times
Posted: Sat May 27, 2006 10:38 am Post Subject: Washing Machine Filling with Water |
My washing machine ( Bosch WVF 2401 ) fills with water when m/c is switched off. How can I fix problem? |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Sat May 27, 2006 10:43 am Post Subject: |
Quite likely it is coming from the sink waste pipe. How does the rubber drain hose from the machine run? |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 0 times
Posted: Sat May 27, 2006 10:45 am Post Subject: |
You could start by turning the isolating valve off that feeds the machine, until you actually need to use it.
Is it filling with clean or dirty water?. Is the power to the machine switched off when it fills? |
scamp
Posted: Sat May 27, 2006 10:53 am Post Subject: |
It is filling with clean water and the electrics are turned off. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sat May 27, 2006 11:30 am Post Subject: |
your inlet valve is letting water by, needs a new one __________________ Do you like music Mr Finch?
Forum = Opinions |
scamp
Posted: Sat May 27, 2006 1:37 pm Post Subject: |
where is the inlet valve? How do I replace? |
breezer
Posted: Sat May 27, 2006 3:49 pm Post Subject: |
inlet valve is at back of m/c where the water inlet hose is connected to __________________ Do you like music Mr Finch?
Forum = Opinions |
