DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Removing and making good old screw plugs
This topic originated from the How to page called Preparing Walls and Ceilings
Click here to return to the page called Preparing Walls and Ceilings.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Flyingspaniard
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 28, 2006 10:43 am    Post Subject:
Reply with quote Thanks
I just trying to prepare my walls for painting and wandered if there were any tricks for removing and making good old plastic plugs from the wall, where there were once hooks and shelves.
I have tried pulling them out with pliers but they break and that just leaves an untidy mess! I don't want to start drilling them out in case there's wiring in the wall... any thoughts?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun May 28, 2006 10:46 am    Post Subject:
drill them out, since there cant be any wiring in the wall because there is a rawl plug there already
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Flyingspaniard
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 28, 2006 10:48 am    Post Subject:
Gr8 thanks
Back to top
 Alert Moderators
jbonding
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 28, 2006 12:04 pm    Post Subject:
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sun May 28, 2006 12:38 pm    Post Subject:
If you want to push a plug in deep, so you can fill over it, put a rather large screw (like a size 10) into it and tap it with your hammer. this will usually drive the plug in, then you can unscrew the screw.
If you want to pull a plug out, drive a screw into it and pull it out with the claw of your hammer. this will probably bring some plaster with it and leave a crater in the wall.
When you fit a new plug, it is best to drive it slightly below the surface of the plaster by tapping the screw before you tighten it. This reduces the risk of the plaster cracking as the plug expands, and also gives a stronger fixing, and is easier to fill (see above) when you decide to remove the fitting in years to come.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Sun May 28, 2006 8:27 pm    Post Subject:
jbonding wrote:
Yep...when it doubt...give em a clout...always works!
__________________
How much!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Shower tiling screw up? See photos 3 660 Fri Sep 15, 2006 7:22 am
new skirting/architraves - how to treat screw/nail heads 3 460 Sat Mar 08, 2008 9:28 pm
Plasterboard nail plugs popping 3 480 Wed Sep 27, 2006 11:20 am
plasterboard raw plugs 12 4420 Tue Mar 06, 2007 4:15 pm
Wall Plugs for ceramic tiles? 2 420 Tue Mar 13, 2007 7:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
