LoopyG
Joined: 29 May 2006 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Mon May 29, 2006 8:36 pm Post Subject: Micro-bore and Condensing combi boilers |
Hi there. Can anyone tell me whether it is possible to use a Condensing combi boiler with micro-bore fed radiators? At the moment I have a regualr gas fired boiler but its massive and noisy and inefficient and I want to change it but I have micro-bore pipes to my rads.
Also, is permanently removing rads a DIY possibility or should I get a professional in? I'm taking down a stud partition wall permanently and at the moment there is a rad on the wall to be removed.
While I'm at it, one more question: I would eventually like to replace my panel radiators with some of those original cast iron style look-a-likes (old fashioned "school" radiators) but will the micro bore make this impossible??
Sorry for all the questions. My only excuse is that I'm a girl and am not really supposed to know about these things
cheers |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Mon May 29, 2006 8:53 pm Post Subject: |
There is usually no problem using a condensing boiler on a microbore system providing it is properly cleaned first.
In theory there should be no problem either using the large cast iron rads. However check the heat outputs very carefully otherwise you will be feeling cold!
Many DIYers remove rads themselves.
Your heating system probably knows nothing about sex. If it helps I always imagine that boilers are female because they are so temperamental !
Tony |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Mon May 29, 2006 11:41 pm Post Subject: |
You mean they're sizzlin hot until you go near them, then they sigh and turn themselves off, eh Tony? |
LoopyG
Agile
Posted: Tue May 30, 2006 12:07 pm Post Subject: |
No Chris, and on further thought its not such a good analogy.
Boilers are very cold when I first meet them and I always get them hot again after a very short time.
Most women that I meet are cold at first and stay cold in spite of all my attentions!
Tony |
