DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
slipper bath water leak
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
kaz285
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 31, 2006 8:20 am    Post Subject:
Reply with quote Thanks
my slipper bath is leaking water down one leg and has been for 2 days, i can think of where its coming from, can anyone help, it hasnt got any cracks in the bath, please help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sat Jun 03, 2006 5:40 pm    Post Subject:
Leaving aside what a slipper bath is, for a moment, is the water running/dripping constantly, or only when you use the bath, or when?
Back to top
 Alert Moderators
kaz285
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 05, 2006 8:24 am    Post Subject:
it seems to be dripping constantly and hasnt stopped for over a week.
Back to top
 Alert Moderators
kaz285
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 05, 2006 8:27 am    Post Subject:
its dripping constantly and hasnt stopped for over a week.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Jun 05, 2006 9:42 am    Post Subject:
If it's dripping all the time, then it sounds like a leak, not in the bath itself, but the supply, such as a tap connector. Is the water at the tap end?
Does this bath have panelling round it; are you able to see the pipework and the underside of the taps? If you can see the drip, put a pan under it (if you haven't already) to prevent the flooring getting wetter.
How long has the bath been installed, and, how long has it been dripping? Has anything been moved or serviced recently, on or around the bath?
Back to top
 Alert Moderators
kaz285
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 05, 2006 10:10 am    Post Subject:
its only been installed about a month and the leak isnt at the tap end its the opposite end, its a clearwater twin skinned sipper bath so the only thing i could think of it water has leaked through the overflow and between the twin skin and is coming out through the skrew hole where the leg is skrewed in but i dont know if that possible.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Jun 05, 2006 10:15 am    Post Subject:
Hadn't thought of that, could be poss, never seen it. If you shine a strong torch from the inside you might be able to see if there is water in the space.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Jun 05, 2006 11:09 am    Post Subject:
Back to top
 Alert Moderators
kaz285
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 05, 2006 1:50 pm    Post Subject:
any further suggestions softus?
could it leaking through the twin skin?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Jun 05, 2006 7:05 pm    Post Subject:
I haven't seen one of these first hand, although I've spent a few minutes browing the InterWeb to see what they're like.
Have you made absolutely sure that the water isn't starting higher up and running down/around the outer surface until it reaches one of the feet?
If it's not that, then logic says that it must be coming from between the layers. If so, if could still be a tap, or an accumulation of water that leaked from the waste when the bath was full.
Either way you run the risk of invalidating the warranty if you start dismantling to do the fault-finding, so JohnD's advice has to be the best of all - call the installer back and ask them to remedy the fault under the terms of your warranty.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leak between bath and taps 4 460 Sat Nov 06, 2004 10:01 pm
LEAK UNDER BRAND NEW BATH 7 520 Fri Sep 28, 2007 9:03 am
new bath leak! 11 460 Wed Jul 19, 2006 7:32 pm
leak below the bath 3 3980 Fri Mar 05, 2004 12:53 pm
Bath waste: overflow tube leak 3 640 Wed Aug 15, 2007 8:01 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
