DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Earthing for new plumbing
This topic originated from the How to page called Installing wiring for kitchen appliances
Click here to return to the page called Installing wiring for kitchen appliances.
  View previous topic :: View next topic
Author Message
dgajjar
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 07, 2006 10:35 am    Post Subject:
Reply with quote Thanks
Can someone please tell me what I need to earth in a new kitchen under the new regulations. We have just put in a new kitchen including plumbing and there is an existing earth wire from the main circuit board which I need to extend and connect to the new plumbing.
All advice appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Wed Jun 07, 2006 10:39 am    Post Subject:
No cross bonding require in kitchens, metallic service pipes entering or leaving the property should be bonded with 10mm˛ to the MET within 600mm of entry and on the consumers side of any meters
Back to top
 Alert Moderators
Mini1961
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 8:36 am    Post Subject:
Earth Bonding
Hi what if your using all plastic fittings for all plumbing, should you still have to bond all kitchen matalic objects as with rads around hse,
Cheers
Mini1961
Back to top
 Alert Moderators
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 6:57 pm    Post Subject:
Re: Earth Bonding
[quote="Mini1961"]
Metallic objects in kitchens no longer need bonding.
That is called supplementary bonding and now only refers to metallic objects in bathrooms.
However, if your mains water pipe (and gas) is copper,it needs bonding this side of the stop tap with 10mm˛ earthing cable.
That's called main equipotential bonding.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 7:52 pm    Post Subject:
And the main bonding conductors needs to be a single unbroken length, so the cable needs to be replaced.
Back to top
 Alert Moderators
Mini1961
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 10:11 pm    Post Subject:
Re: Earth Bonding
[quote="luminaire"]
water plastic and gas not in yet i will have to bond it if i hear you right as with copper connectiion in to hot water tank, i am so surprised you do not have to bond the kitchen sink?
Cheers you all for your relpys
Mini1961
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Jul 25, 2007 10:16 pm    Post Subject:
Nope. Supplementary in kitchens was removed in the 16th, although a heck of a lot of it is still done...
When you say "water plastic", do you mean incoming or outgoing (from the stopcock)?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Mini1961
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 10:27 pm    Post Subject:
in bound 25mm blue pipe to brass stop cock then 22mm plastic push fit,
ta
Mini1961
Back to top
 Alert Moderators
pdcelec
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 11:28 pm    Post Subject:
all extraneous coductive parts need bonding no matter where they are
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Thu Jul 26, 2007 5:40 am    Post Subject:
No - You could through crimp.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Jul 26, 2007 8:19 am    Post Subject:
AFAIK, you can use ring crimps at the earth strap too.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Simple bonding question post new plumbing... 6 600 Mon Jan 22, 2007 8:53 pm
Side splitting thread on plumbing forum 7 740 Wed Feb 07, 2007 10:06 am
Kitchen Plumbing Earth Bonding 3 520 Mon Sep 27, 2004 9:07 pm
Electrical/Plumbing? 9 720 Tue May 18, 2004 10:19 pm
Plastic push fit plumbing 5 780 Mon Jan 26, 2004 6:54 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
