DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dripping pipe
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
MrBen
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 07, 2006 12:21 pm    Post Subject:
Dripping pipe
Reply with quote Thanks
I have recently noticed a drip (which becomes a puddle) icon_sad.gif where my overflow pipe is which comes from my cistern in the bathroom. I have tried putting sealent on it but it doesnt do anything. I think its lead. does anyone know of a cheap fix? I know i should probably replace the ballcock in the cistern but this will be expensive wont it?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 07, 2006 12:53 pm    Post Subject:
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 07, 2006 12:57 pm    Post Subject:
Though personally I prefer this sort which cost nearly six pounds but are a lot quieter.
Back to top
 Alert Moderators
MrBen
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 07, 2006 3:36 pm    Post Subject:
nice one. is this the correct thing for the cistern. The one thats in my upstairs hot water tank boiler cupboard?Is this easy to fix on and where can i get one? what are they called?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 07, 2006 3:49 pm    Post Subject:
Take a torch and look at the old one. See how long it is and if it is attached to a pipe from the side of the cistern (like the one in my picture). Measure its length. It may be made of brass or plastic. If it is brass you will need a new plastic float as well, if plastic you can re-use the old one. Observe the various nuts and consider if you already have an adjustable spanner to fit.
I call it a ball-cock. People who are embarrassed to mention "balls" or "cocks" may call it a float valve.
Make your way to a plumbers merchant, DIY store or ironmongers. Try to get one the same length as your old one, although if, when you were measuring, you saw you had plenty of room, a longer one will be OK.
Take the new one home and tinker with the nuts until you understand how it is fitted, and with the adjusting screw until you understand how the water level is set. Then turn off the water supply and remove the old one, fit the new one, turn on, and see if you have any leaks.
Back to top
 Alert Moderators
noodlz
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 07, 2006 4:13 pm    Post Subject:
MrBen, is it the leak from the toilet overflow?
If from the toilet overflow, just need to open cistern lid, shut off supply and as JohnD says, can replace float valve altogether, but probably only need to replace the diaphragm in the valve (usually a small black rubber washer) Make sure you note which way you took it out and put new one in the same way.
These washers often perish - cheap and easy to replace.
If leak from overflow pipe from tank in loft, get out the torch and ladder and same again.
Invest in a decent DIY manual if you can turn your hand to little jobs - will probably save you a lot in the long run for minor problems like this.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 07, 2006 4:19 pm    Post Subject:
Good point about the washer - i usually fit a new ballcock for speed, then if I feel like it, take the old one apart on the kitchen table at my leisure and fit a new washer, then put the repaired valve up in the loft, next to the cistern, ready for next time.
I don't like replacing washers in situ because of the bits that slip from my fingers and fall to the bottom of the tank in dark and cramped conditions.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Dripping Overflow Pipe 9 1120 Fri Jun 02, 2006 8:31 pm
Dripping Overflow Pipe 6 840 Tue Jul 11, 2006 4:35 am
Trouble with overflow pipe that keeps dripping 2 360 Sun Sep 28, 2008 10:13 am
Dripping Overflow Pipe 6 360 Mon Sep 22, 2008 10:53 am
Boiler drain pipe has been dripping for 3 days now... 4 320 Wed Dec 31, 2008 10:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
