The leaflet in the link above talks about putting a 'welt' above the opening (which I understand is basically a couple of bends). . as far as I can see this is to stop water running down the surface of the lead sheet. As I'm using this on curvy pan tiles . . . . this 'welt' is going to be difficult, and will make the tiles stick up I believe . . . so I propose not to use a welt. Can anyone see this being a problem.
Is this all the weatherproofing I need (apart from the plastic thing that seals the plastic pipe to the lead pipe). I don't need one of those aluminium things I've seen with a rubber ring in the middle (which I feel are for flat slate roofs).
Thanks for any help.
Phil Johnson
PS - Any (reasonally price) structural engineers round here want some work?
Joined: 04 Jan 2006 Posts: 268 Location: Essex, United Kingdom Thanked: 5 times
Posted: Fri Jun 09, 2006 2:44 pm Post Subject:
Have you got concrete or clay pantiles?
If you have concrete it is easier to fit the manufacturer's vent tile which replaces one of the roof tiles.
If you have clay then the lead slate is the way to go and the welt at the top is belt and braces, but it is very easy to do you only have to fold the lead back on itself.
Joined: 09 Jun 2006 Posts: 4 Location: Norfolk, United Kingdom Thanked: 0 times
Posted: Fri Jun 09, 2006 3:46 pm Post Subject:
They are clay (old red) tiles.
Bought all the stuff at lunchtime. I'm going to silicone in place the plastic ring the sits on top of the lead slate.
Saw the other things you mentioned . . . . . liked them . . . but they looked a little flimsy . . . . this lead slate thing should provide a fair amount of support (in case a eagle fancies pearching on it ).
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
