Hoover AM110 won't final spin
11 Jun 2006
Wolverhampton
Hope someone can help . The machine won't go into a final spin on any programme . Checked brushes 10mm at longest point & Pressure switch
tube & bottle all ok any help much appreciated .
no idea what so ever.
but usualy 10mm is short, you should also only be measuring the protruding carbon, not the whole thing.
yep thats what I was measuring from the carbon holder to the end of the longest side of the brush .
You have checked that the water is completely drain from the machine and the filter is clear, some of the new machines will not spiun if not drained within a certain time, but breezers right for the sake of £2-00 change the brushes.
If the machine is not spinning after this you may be looking at a faulty electronic unit call an engineer.
May sure you turn the mahine off at the wall adn remove the plug if possible. :idea:
:eek:
:eek: :eek: :eek: :eek: :eek:
brushes or module mate!!!
you have some strange repair methods laundry spares or repair!!
Checked the filter & the operation of the pressure switch ,took the bottle for the pressure switch off the drum checked if it was clear ,so cheapest first............ brushes then see what happens .
Well update , I've changed the brushes still got the same problem .What's next on the usual suspects list ?
