DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
3 bulb pedant to single pendant
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
kathyq
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 12, 2006 10:21 am    Post Subject:
Reply with quote Thanks
We have two 3-bulb pendant lights in the living room that I want to replace with single pendants. I don\\\'t want to go messing about up there without knowing what to expect, so can anyone advise:
a) what the wiring configuration is likely to be - will there be wires for each bulb, or a single wiring group with the distribution done by the pendant itself? If there are separate sets of wires for each bulb, are these easy to convert to fit a single pendant or is this a job for an electrician?
b) the existing pendant is fixed by a gold ceiling rose & chain - I\\\'d like to remove all this but there are no obvious screws fixing it to the ceiling. How is it likely to be fixed, and what\\\'s the best way to remove it, without bringing the ceiling down?!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Jun 12, 2006 12:46 pm    Post Subject:
There is only likely going to be one set of wires from the light fitting (1L, 1N and 1 / 2Earths) providing you are talking of the same light fitting as below. There are different ways that the light can be wired into the fixed wiring, you will need to check how many wires/cables there are above the fitting first. Sometimes there is a black switch wire in the rose which need to be identified, if connected to neutral it will cause the fuse to blow. There are diagrams in the Sticky section at the top of the Electrics UK forum which may be of help.
You may need to unscrew the support which holds the chain to the rose allowing the rose cover to drop down. You may need to split the first link and remove it from the support to allow you to spin it. Be carefull as you will need to take the full weight of the light, remove glass shades and lamps 1st, turn the power off to the circuit.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New Pendant 10 440 Mon Mar 10, 2008 11:19 am
Adding an extra pendant light to existing switch / circuit 2 380 Thu Feb 21, 2008 11:52 am
The Diagram in 'New Pendant ' Post 6 360 Tue Mar 11, 2008 5:57 pm
Junction box to pendant lighting (1 switch 2 lights) 4 280 Sat Apr 12, 2008 10:17 pm
black pendant (ceiling rose?), long drop pendant 9 1440 Fri Jun 27, 2008 1:14 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
