DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Pop up Waste Turn front removal
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
styeffo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 12, 2006 5:52 pm    Post Subject:
Reply with quote Thanks
Hi We have bought and had fitted a bathroom suite from B&Q, the problem we have is with the actual chrome turn handle for the pop up waste.
When you turn it, it moves physically around the hole, and as such we gave up trying to use it and just pulled the plug up with our nails etc.
How do you remove the handle in order to tighten the screw holding the plastic Bath waste against the Tub itself?
Help!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Jun 12, 2006 7:24 pm    Post Subject:
If you feel round the knob, you will probably find a little hole in the rim. You can poke a screwdriver in this and undo the grubsgrew that holds the knob on its shaft. If you take this off you should be able to see how it is assembled.
You also need to take off the bath panel and hold or twist the banjo like thing on the outside of the bath that the overflow screws into.
Back to top
 Alert Moderators
styeffo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 12, 2006 8:13 pm    Post Subject:
Cheers, i was wondering if that was it or whether that a new funky overflow hole!
I shall try it out and let you know!
Back to top
 Alert Moderators
m1sterken
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 11, 2006 11:27 pm    Post Subject:
How to remove the control knob for a pop-up bath plug
I have slackened off the small grub-screw - so much in fact that it has fallen out of the screw hole - but I still cannot get the handle off.
I tried pulling both halves apart, but to no avail.
I don't yet want to try and force it off in case I damage the handle, or worse still, the bath itself.
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 11, 2006 11:39 pm    Post Subject:
pull
__________________
You live to learn and Learn to live
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Warm Front Grant 2 220 Wed Mar 19, 2008 11:34 pm
Fire Front & Back Boiler Question 8 1820 Sat Apr 05, 2008 10:52 pm
Ideal isar he30 - no power to front display pannel 12 2040 Thu May 15, 2008 10:15 am
Warm Front & Building Regulations 8 520 Sun Mar 16, 2008 11:53 pm
front panel of combustion chamber 29 1160 Sat Feb 23, 2008 9:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
