TimP
Joined: 06 Jan 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Jan 06, 2004 4:57 pm Post Subject: Fused Spur |
I have taken a spur from a ring main socket to feed some low voltage downlighters in kitchen cabinets. The spur goes to a fused switch. The outlet from the switch goes to a double socket for the lights. Can I run two cables from the fused switch, thus feeding two sockets? Everything I read says one spur only from a ring main socket. Would my proposal count as two spurs or is it still classed as one spur since it is only feeding one fused switch? |
Millennium_Boy
Joined: 29 Nov 2003 Posts: 118 Location: United Kingdom Thanked: 0 times
Posted: Tue Jan 06, 2004 6:17 pm Post Subject: Fused Spurs |
It appears you have a Fused Spur, so yes you can run multiple sockets, provided, as the regs state, the Fuse shall NOT exceed 13a on a ring main. |
