DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Heat resistant glue for oven glass
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
noodlz
from United Kingdom
PostPosted: Thu Jun 15, 2006 7:16 pm Reply with quote
Inside glass to built-in oven has come loose and needs to be glued back together...problem is everything I've tried eventually gives and the glass drops again!
Can't use oven without it and all it needs is to be glued back into place...and stay there! Otherwise will have to replace door or whole oven which will be a pain.
Anyone got any ideas what I could use?
Back to top
 Alert Moderators
noodlz
from United Kingdom
PostPosted: Fri Jun 16, 2006 10:07 am Reply with quote
Found the solution to my problem:
http://www.absealantsltd.com/sealants.htm#High%20Temperature
that's the high temperature sealant silicone....
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 25 times
PostPosted: Fri Jun 16, 2006 7:46 pm Reply with quote
When I worked for Indesit, had to glue quite a lot of door glass in.
Clean the old stuff off and make sure the glue area is clean and dry.
Run a fairly thick bead of high temperature silicone around the frame. Put the glass in place then put a weight on top of the glass. Leave it for 24 hours, it'll set fine then and will last for ages.
Without the weight and letting it dry it won't last long.
Back to top
 Alert Moderators
bob white
from United Kingdom
PostPosted: Sat Jun 17, 2006 6:18 pm Reply with quote
hi email me i send you info on some
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
how to glue inside glass to oven door? 5 2600 Wed Aug 08, 2007 4:56 pm
Glue for an oven door seal 6 1540 Fri Nov 06, 2009 7:55 am
replacement exterior oven door glass 3 300 Sat May 07, 2011 1:30 pm
Stoves Oven Door Outer Glass 7 60 Sun Aug 28, 2011 4:16 pm
NEFF electric oven glass viewing panel 4 600 Thu Jul 24, 2008 10:25 pm
DIYnot
