DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Water escaping
This topic originated from the How to page called Tiling around a bath
Click here to return to the page called Tiling around a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Rachelshaw
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 17, 2006 11:04 am    Post Subject:
Water escaping
Reply with quote Thanks
I have water leaking down the side of my bath on the wall it has been tiled.
I have resealed the bath and also regrouted the tiles around the bath on a couple of occasions. Frustratingly, it is still leaking but there is no evidence of cracks so I cannot work out how it is happening.
It is definitely to do with the grouting as it only happens when having a shower.
The only suggestion I have had from friends to solve the problem is to put a shower curtain up on this wall. However, I think that would look unattractive and I am sure there must be another way to solve it.
Does anybody have any ideas? Thank you.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sat Jun 17, 2006 11:55 am    Post Subject:
To positively eliminate the bath seal, stand in the bath, and spray water from the shower head at the seal only (not the tiles above the seal), do this for a few minutes then check for water leaking. If not then you know the seal is good. If it doesn't leak, come back and we'll go further.
Back to top
 Alert Moderators
Rachelshaw
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 17, 2006 12:41 pm    Post Subject:
Thanks for reply. I have tried as you said and no water has generally seeped through (although it is quite hard as I have a powershower so hard to not get spray everywhere).
I then had a normal shower and the towel underneath is quite damp again.
Does this mean it maybe the row of tiles above the bath? This row is approx a quarter of a tile, which slants slightly from the bath to connect it to the first row of proper tiles which lie flat to the wall. I have regrouted these tiles before (with obviously no success to solve the problem). Maybe it was the type of grout I was using (although it was waterproof).
Thanks again for any advice
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sat Jun 17, 2006 10:16 pm    Post Subject:
Ok now we're looking at the corner (I'm assuming you have 2 tiled walls around your bath) where the 2 walls meet. Try aiming the water just down this joint and see what happens. Is this joint grouted or siliconed?
Back to top
 Alert Moderators
Rachelshaw
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 18, 2006 6:57 am    Post Subject:
The corner is silicon. However I have tried it and it is not leaking in this area.
The leaking is exacly halfway along the bath. I have a feeling it is between the first row of tiles and the second row, where the quarter of the tile meets the next full row of tiles.
Thanks.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon Jun 19, 2006 12:16 pm    Post Subject:
If you tap those tiles with your knuckle, do they sound hollow? They may be loose and being held mainly with the sealant. You may need to refit those tiles again and re-grout. Can you see any cracking in the grout?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Jun 19, 2006 1:25 pm    Post Subject:
Is there anything passing through the tiles, like a soapholder or a pipe? Or a shower rail held on by concealed screws?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
water based masonry paint over pliolite masonry? 2 960 Sat Jun 14, 2008 8:31 pm
Water based paint for radiator 2 240 Fri Jun 20, 2008 5:34 pm
What method do you guys use to water down emulsion 26 900 Wed Jul 16, 2008 8:20 pm
Water Damage 4 240 Sat Jul 19, 2008 10:48 am
solvent based versus water based 8 600 Sat May 10, 2008 11:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
