DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Exterior door frame question
This topic originated from the How to page called Preparing an old exterior door frame
Click here to return to the page called Preparing an old exterior door frame.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
John Duclos
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 19, 2006 2:21 pm    Post Subject:
Reply with quote Thanks
I want to replace my aging aluminium back door & rotting frame with a timber door & new frame. It is a Victorian property (1904) with cavity walls. Does the frame fit in the outer brick aperture or through the inner aperture against the inner face of the outer wall? TIA icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Jeeman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 26, 2006 9:36 am    Post Subject:
Replacing Aging Aluminium door frame
There is no set rule for doing this but since you have a cavity wall the inner side will be made from Block and the the outer hopefully from bricks.
The trick here is to screw the frame into the blocks and allow about 1 inch to overlap onto the bricks (covering the gap in the middle.
Back to top
 Alert Moderators
Jeeman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 26, 2006 9:39 am    Post Subject:
Re: Replacing Aging Aluminium door frame
[quote="Jeeman"] If you need a job doing right for gods sake just do it yourself!quote]
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
fitting exterior door frame 6 10420 Fri Mar 02, 2007 8:33 pm
Unusual exterior door sizes...help? 2 180 Tue Sep 08, 2009 4:44 pm
Exterior door threshold wood floor problem 3 740 Wed Feb 18, 2009 10:38 am
What's the point of a sill? New door order question 4 620 Sun Feb 15, 2009 3:47 pm
custom exterior door? 2 220 Mon Sep 14, 2009 4:00 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
