DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Faulty ceiling spotlight
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
simonj007
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 19, 2006 3:45 pm    Post Subject:
Reply with quote Thanks
I have one spotlight not working in a set of 10 - all sunken into a ceiling.
I replaced the bulb but the one spot still doesn't work??
Any ideas?
Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 19, 2006 4:29 pm    Post Subject:
And its always been like this ? or it used to work ? and they are mains ? or they are SELV ? and they all have their own transformers ? etc, etc.
Swap it with a working lamp, don't always assume that new things are never defective.
Failing that, some of the above may help.....
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jun 19, 2006 5:39 pm    Post Subject:
Pull the wire that the bulb attaches to - see if theres a transformer attached to it. If there is, replace said transformer.
If the fitting is solid (no dangly wire), simply pull it from the ceiling and if a transformer falls out after it, there's the culprit.
However, as bathjobby said, if may be a dud bulb.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon Jun 19, 2006 5:47 pm    Post Subject:
If it is a 12V downlighter then is is not unknown for the lampholder to burn out. These are dead easy to replace and cost about 12p
Back to top
 Alert Moderators
remus
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 29, 2007 8:07 am    Post Subject:
FAILED LIGHTS
Hello, I turned on our bathroom lights yesterday evening and only one of the 6 12V 50W bulbs came on. I've changed one bulb and confirmed that it's not a faulty bulb. I hope its not the transformer as it means lifting carpets and flooring to find it! Any ideas anyone please?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Ceiling spotlight faulty but works when not in its housing 4 520 Sun Sep 17, 2006 9:16 am
Faulty halogen spotlight 4 200 Mon Jun 15, 2009 2:42 pm
Changing a ceiling spotlight back to a pendant light fitting 3 2320 Mon Feb 06, 2006 7:05 pm
Newbie question - wires too short for ceiling spotlight! 20 1080 Tue Mar 30, 2004 1:40 pm
ceiling rose to spotlight help - neutral wires 2 300 Sat Jun 21, 2008 3:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
