DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
final sub circuits
This topic originated from the How to page called Converting a radial circuit to ring circuits
Click here to return to the page called Converting a radial circuit to ring circuits.
  View previous topic :: View next topic
Author Message
Guest
Thanked: 0 times
PostPosted: Fri Aug 23, 2002 11:13 am    Post Subject:
final sub circuits
Please can you advise me. My friend and I are trying to figure out something we cannot find in the regs. We both have an electrical background.
We are trying to find out why you cannot put more than one circuit in a fuseway. What started it was when we inspected a kitchen and found three items (pretend they are 3 hobs for now to keep it simple)all fed from one circuit as a radial. Each one has the correct cable (2.5mm) and the fuse is 20Amp. If one item goes faulty the fuse will blow (obviously all 3 items will then be off)so it works safely as the cable is right and so is the fuse. Whats wrong with it? Taking it to the extreme what stops you putting ten radials in one circuit apart from common sense, ie a blown fuse would mean the loss of ten items until fuse replacement? Basically we would also like to know how many circuits can be fed from one way. I believe you can run one spur from the ring, actually from the fuse way which would give you 3 cables connected to the way. What is the limit?
Any help would be appreciated.
Yours faithfully
Demo Zambourides
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wileecoyote
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 09, 2004 2:29 am    Post Subject:
Reply with quote Thanks
As far as i am aware in reality there is no limit.
The most important things are... the fuse/circuit breaker must be of a lower rating than the cable therefore the fuse/mcb will burn before the cable will.
So in terms of capacity
CABLE greater than FUSE greater than LOAD
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jan 09, 2004 6:04 am    Post Subject:
yes there is, one spur / socket
Also may i suggest that you look at the date of a post before you relpy, the one you replied to was written on Aug 23, 2002 which makes it just over 16 months old, think they may have figured it out by now icon_wink.gif
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Final circuits sharing box 3 320 Sun Jun 15, 2008 12:05 am
Working out V.drop on ring final circuits 3 300 Mon Feb 25, 2008 9:42 am
R1 + RN on Ring final circuits 3 400 Thu Apr 19, 2007 6:51 pm
Final circuits sharing MK Grid 3 400 Mon Jun 16, 2008 2:36 pm
High integrity earthing and ring final circuits. 82 4300 Mon Jul 21, 2008 8:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
