Agile said:Clearly it must be the air pressure switch as you have already suggested to someone else!
Inter mal Iraq? Ouwain bete inter al UK ? Al Swansea?
kevplumb said:now now mr glazier you know it's the slow start foo foo valve that's jammed
Exactly - easy to get at.Use the safety to drain down
Ooo err, if it starts gluggin out while you have the DV out and you're over carpet...Be brave work on the boiler with the system full of water - just have the bungs handy
Err, just a disc sitting in the pipe somwhere innit? With a usually-perished O ring you 're better off without? Or do you mean something different?Ditch white flow restrictor
