DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Urgent Advice on post hole fixing
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
  View previous topic :: View next topic
Author Message
BobAlger
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 21, 2006 6:59 am    Post Subject:
Reply with quote Thanks
Please can someone advise on the correct hole sizes and amount of postcrete to be used for fixing 8' concrete fence posts as I am somewhat confused. Work starts tomorrow (22nd June) so an early response would be appreciated.
My current plan is to use a petrol driven auger to drill 8" round holes to a depth of 21" and to fix the posts using Postcrete. The DIY shop said use one bag per hole but another website indicates that this will only take about 1/2 bag for each hole of these dimensions and my concern is whether this is sufficient. What I don\\\'t really understand is whether its the hole that is supporting the post and the Postcrete is simply filling the gap or vice versa.
Many thanks
Bob Alger
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 21, 2006 7:24 am    Post Subject:
The ground provides the support and the concrete stops the post from rattling about. It also provides a wider bearing to spread the forces from the post over a wider expanse of ground.
A deep hole is better than a wide one. Your hole borer should be good for that. Any soil that is loosened by diging needs to be excavated and replaced by concrete, since loose soil is not supportive.
If the hole is too wide you can economise on concrete by packing large stones or pieces of brick in, making sure each is well encased in concrete so you have a monolithic mass.
The top few inches of the hole do not provide much support, but it is useful to bench up the top of the concrete towards the post to help rain run away from it (not important of it is a concrete post) and so that you do not have a great wide patch of concrete showing through the ground.
Back to top
 Alert Moderators
BobAlger
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 21, 2006 3:12 pm    Post Subject:
Thanks JohnD
Thanks JohnD for you prompt reply which has put my mind at rest.
All I need now is this wind to die down before tomorrow!!
Thanks again.
Bob Alger
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jun 21, 2006 3:16 pm    Post Subject:
p.s. if you're using concrete gravel boards (I think they're great) sink your posts so that the boards will be a couple of inches into the soil. You can easily scrape out a groove in the ground for it and brush back after.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Wed Jun 21, 2006 4:03 pm    Post Subject:
i always use some hardcore at the bottom of the hole to pack out the post so that it is stable and level before the concrete goes in. It stops it moving during the post mix going in and it gives a much firmer post
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
lawn mower urgent help needed 3 380 Wed May 28, 2008 9:42 am
Help with removing fence treatment..URGENT 10 400 Wed Jun 03, 2009 9:32 am
Post hole borer 2 640 Mon Feb 20, 2006 11:34 am
Best fence post hole boring tool 7 2900 Thu May 31, 2007 9:03 am
Post hole borer or Trenching Shovel? 13 1700 Wed Feb 07, 2007 1:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
