Joined: 21 Jun 2006 Posts: 5 Location: United Kingdom Thanked: 0 times
Posted: Thu Jun 22, 2006 10:45 am Post Subject:
Washing machine on extension lead
I am trying to relocate my washing machine and tumble dryer (2 units) to my garden shed.
Current location is in utility room. The shed is just outside that room. I was going to get an electrician in to wire in extra sockets to the shed but I am trying to save money.
Can I run an extension lead from the current socket out into the shed and plug both appliances into that or will it overload the extension?
Not knowing much about it I'm asking for help on the practicalities of it and whether it is safe.
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Jun 22, 2006 10:57 am Post Subject:
Having a proper installation would be the right thing to do, with a dedicated RCD protected and fused circuit to the outbuilding. Start saving up.
You will have to use separate plugs, separate sockets, and separate cables. Not a double socvket for both appliances. Get a couple of RCD adaptors (at the house end) at the least as they will be outside the house and damp or wet. Both the extension cables must be suitable for 13Amp loads. Don't get them much longer than you need.
Roll up and put away the extensions between use as they will deteriorate once you stop bothering and they are exposed to sun and trampling.
Posted: Thu Jun 22, 2006 6:20 pm Post Subject:
I dare not reply.
Yes I was trying to cut corners and keep expense down although I take on board the fact that I shouldn't be.
I shall engage the services of a professional.
Regarding the question about the water in the shed. I was intending on extending current hose through said wall and into said shed. That question was under a different topic.
I wanted to DIY as much as possible but the electrics are way above my ability so better extend the overdraft.
Thanks for the sensible and not so sensible answers!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
