DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
rubber floor tiles on floorboards
This topic originated from the How to page called Rubber tiles
Click here to return to the page called Rubber tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
takeachance
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 23, 2006 5:36 pm    Post Subject:
Reply with quote Thanks
I\\\'m planning to lay rubber floor tiles on floorboards but guess there should be something to level the surface in between. What would be best to use in a (small) bathroom? Screed? Hardboard? Ideally I\\\'d like to make this floor waterproof, so it doesn\\\'t leak downstairs even if there\\\'s a spill. Can anyone help?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wood wizard
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 30, 2006 10:33 pm    Post Subject:
does it matter how much you lift the height of the floor by?
Back to top
 Alert Moderators
takeachance
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 04, 2006 3:53 pm    Post Subject:
rubber floortiles on floorboards
I'm told we have to lay 6ml marine ply and cut round the loo. If this is the case then there's plenty of room to raise the floor level by that much and more.
However someone else said it was possible to undo the bolts on the loo and that way make no cuts to the flooring, which would be much better.
The latest authority tells me it's not worth the risk.
I don't know who's likely to be right. Any tips?
Back to top
 Alert Moderators
alexmarkham
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 03, 2006 9:31 pm    Post Subject:
Hi, I work for a rubber flooring company and our guidelines would be as follows;
The best way to install over floorboards is to install 6mm plywood with ring shank nails to prevent movement. It is much easier to remove toilet and sink pedestals and then adhere the rubber flooring to the plywood and then screw the pedestal back down through the flooring into the subfloor. The join between the pedestal and flooring can then be sealed with a thin bead of silicone sealant.
Hope this helps!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Rubber garage floor tiles 3 1140 Sun Feb 10, 2008 9:35 am
rubber tiles on cork 2 1400 Wed Aug 08, 2007 6:43 pm
Epoxy Resin Paint - self leveling compound - rubber tiles?!? 3 3000 Sun Feb 10, 2008 10:11 pm
REMOVING RUBBER TILES FROM A WODDEN SUBFLOOR 3 380 Sat Mar 22, 2008 6:06 pm
Rubber floor meets wooden floor - what do I use? 4 980 Wed Oct 12, 2005 2:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
