Pressure was on 3.5bar... Engineer drained boiler, recharged expanssion vessel to 1.5bar then put pressure to 1.5bar with cold water feed turned off to boiler (so no water coming out of hot water tap). Turned on heating and went to 2.5 within 20mins, so turned boiler off and now 24hrs later pressure has dropped to 0.5bar.
Earlier in the week he tried draining the boiler completely then turned on the cold water mains to combi, so heating side pressure was on 0 bar. The pressure within about 5 hours went up to 3.5bar (on heating side).
Could the water be mixing in the main heat exhanger into the heating side (as there is no seperate dhw heat exchanger on this boiler) or could it be a problem with the expanssion vessel (small hole possibly)?
