DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Tap won't turn off
This topic originated from the How to page called Repairing a leaking tap
Click here to return to the page called Repairing a leaking tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Tapdancer
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 26, 2006 5:16 pm    Post Subject:
Tap won't turn off
Reply with quote Thanks
Help! Last night I ran a bath and the hot water tap wouldn't turn off. As a result, I've had to turn all the water off and empty the tank. So now I have no water. The tap is a mixer with separate hot and cold knobs, which turn 90 degrees with on at one end and off at the other end. The taps are only 18 months old and because it happened so suddenly, I am not sure that it is a washer problem. Also, I can't undo the brass nut to get to the washer bit. Can anyone tell me: how I can ease the nut to get to the inside of the tap; and whether it is likely to be the washer or the seating. Can I do this job without having to go under the bath because that end of the bath is in a little alcove and is really hard to get in under to look. Please help because I'm really struggling with no water and I am skint so can't afford a plumber until pay day.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Jun 26, 2006 6:58 pm    Post Subject:
Hopefully you "Just" need a bigger spanner, then you'll find the tap valve has come apart and will go back together again.
More likely though is that it won't, and if it's not a common make you'll not get a new valve part for it icon_cry.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
turn off hot water 9 260 Sat Sep 20, 2008 4:07 pm
Worcester Bosch 230 (Gas) can't turn on central heating 3 220 Tue Sep 23, 2008 1:39 pm
Central Heating Didn't Turn Off 7 240 Fri Oct 03, 2008 6:31 am
Heating wont turn off 9 420 Wed Sep 17, 2008 7:48 pm
Insurance company, heating would not turn on. Won't fix it! 76 2360 Sat Aug 30, 2008 9:35 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
