DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cistern
This topic originated from the How to page called Plumbing in a cistern
Click here to return to the page called Plumbing in a cistern.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
morpheus
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 28, 2006 8:03 pm    Post Subject:
Cistern
Reply with quote Thanks
Despite turning the water off , my cistern is still filling itself up and overflowing
What do I need to do ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Al-Glasgow
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 28, 2006 8:06 pm    Post Subject:
cold water storage system do you mean ?.
I guess the ball valve is at fault, when you lift the arm the water should stop filling the tank.
Turn off the rising main, and service the ball valve.
Al
Back to top
 Alert Moderators
fitz1
from United Kingdom
Thanked: 10 times
PostPosted: Wed Jun 28, 2006 8:12 pm    Post Subject:
probably tank fed from storage tank. look for big tank with two 22mm pipes coming off it. trace pipe to valves. if no valves , turn off the main and open all taps until water stops. fit isolation to toilet and refil. if this doesnt work, look for a second main, as some older houses used to have a main at the back of the house for the outside loo.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cistern Connections 4 200 Tue Jul 01, 2008 1:20 pm
Connection to concealed cistern 3 240 Sun Jun 29, 2008 8:00 pm
Conceala 2 Cistern - Dual flush confusion 4 500 Thu Jun 26, 2008 5:58 pm
Flexible hose size for toilet cistern 4 120 Wed Jun 25, 2008 4:03 pm
Fixing toilet cistern to pan - is silicone required 5 480 Thu Jul 03, 2008 8:21 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
