Servis W/D not taking in fabric softener
29 Jun 2006
My Servis Washer Dryer 1300 is just over a year old and has stopped taking in fabric softener. I have taken out the drawer and cleaned it - it had become quite gunky possibly also due to using concentrated softener. My softener is left in the section (I don\\\'t fill it as it\\\'s concentrated) but it doesn\\\'t seem to have excess water in there, so I seem to think the water isn\\\'t getting in. I also haven\\\'t seen the water going in on a rinse cycle.
I have cleaned both the drawer and what I can get at with the drawer being out. I have also stuck a straw up the hole where I think the water comes through, and it doesn\\\'t appear to be blocked in any way.
Can anyone suggest anything? I\\\'m thinking it may be a valve and that I may have to call someone out. I hate my clothes and towels not being softened! I have the washer on just now and have put it to the rinse cycle and have poured a glass of water in with the softener to try that meanwhile.
Not sure if you ever managed to get this sorted. Can anyone advise what the cause might be? There are no problems with the detergent sections filling with water, just the softener section. I too, have cleaned the drawer thoroughly and also the inside of the machine where the drawer sits to ensure there was no congealed softener.
Thanks,
Mandy
Condtioner dispensers usually has a lift-off cover that will reveal a few water channels and one or two short standpipes moulded into the tray, covered by inverted cup shapes moulded into the cover. The channels, standpipes and the cups can get bunged up with residue from the conditioner and need cleaning out.
If all is clean and working you should be able to test it by holding the complete dispenser tray over the kitchen sink and slowly filling the conditioner compartment with water. Nothing should come out of the outlet in the bottom of the tray until the dispenser is completely full, then it should start to syphon itself empty, not stopping until the dispenser is empty.
You can usually check the machine by opening the drawer a bit when it starts the rinse cycle to see if water is feeding into the dispenser.
