DIYnot
Local | Network
   DIYnot > Forums
Local | Network
washer change
This topic originated from the How to page called Replacing a washer in a reverse pressure tap
Click here to return to the page called Replacing a washer in a reverse pressure tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
markbillingham
from United Kingdom
PostPosted: Sat Jul 01, 2006 8:34 pm Reply with quote
i have a dripping tap in the bathroom which is a mixer tap. there is no screw to undo to remove the tap,it is just in one piece. how do i take off the tap to change the washer?
Back to top
 Alert Moderators
tincup
from United Kingdom
Thanked: 43 times
PostPosted: Sat Jul 01, 2006 9:15 pm Reply with quote
Hi
This maybe a pull off type. They can be tricky to remove.
A rubber washing up glove can be helpful or a thick elastic band wrapped round the tap head could help.
Pulling up and rocking normally does the trick.
Hope this helps.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Noisy pipe since washer change 5 300 Wed Jul 14, 2010 9:05 pm
Problem removing tap unit to change washer 2 40 Tue Jan 03, 2012 9:55 pm
How do I change a washer on this type of tap 4 700 Mon Aug 03, 2009 8:35 pm
Change toilet waste to washer waste. 2 220 Fri Jul 09, 2010 1:20 pm
Change hot water tap washer 5 460 Mon Mar 15, 2010 5:46 pm
DIYnot
