Source for 3-port Mixing Valves
19 Jun 2006
Essex
Can anyone recommend a source for 3-port mixing valves & actuators?
I need to replace a 3/4" Satchwell MB rotary shoe valve on an weather compensated system. The mixing valve has started leaking at the spindle. A service kit costs more than a whole valve, so it looks like I need a new valve & 24V 0-10V actuator.
This is not a mid-position valve and it is not a thermostatic mixing valve.
Otherwise anyone know where you can get variable speed injection mixing pumps?
TIA
Proabably easiest to use another the same and swap the guts?
