Joined: 03 Jul 2006 Posts: 2 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Mon Jul 03, 2006 12:20 pm Post Subject:
Adding a foreign socket to a ring main
Please can anybody tell me if it is possible to add a European socket type (Shuko)to a ring main in the UK? I travel between the UK and France a lot and have appliances bought in both countries. Why do European countries have no fuses within their plugs??
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Mon Jul 03, 2006 12:51 pm Post Subject:
I actually prefer the european system, 16A radials, small unfused plugs, in many ways the ring final circuit was a compromise and many of its benifiets are not relevant to modern useage patterns. The ring is usful to have and can be usful at times, but as a whole a lot of the time a radial is more appropiate
Anyway I can't see any harm in connecting the shuko outlet to the ring via a 13A FCU (or a 16A breaker), however its possibly against the wireing regulations because its not a BS marked bit of kit
But what you must not do is connect the socket directly to the ring, appliances are designed with the expectation that the circuit will be protected with a 16A device
Posted: Tue Jul 04, 2006 10:23 am Post Subject:
Thanks for all your responses. The applicances I tend to bring backwards and forwards are mainly transformers for laptop, iPod, etc, so low power stuff but buying new transformers is quite costly.
Also I like the European plug as it is so small and less sightly.
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Tue Jul 04, 2006 11:27 pm Post Subject:
yeah i've always thought travel adaptors look rather flimsy, the pins on most adaptors for taking british equipment to the continant for example are noticablly thinner than those on real schuko and french plugs.
also the other thing i find highly distrurbing is that visitor adaptors are sold in this country that will accept a schuko or french plug but not earth it, theese adaptors carry no warning not to use them with such plugs and i have seen them used with them in commercial settings!
the flip open euro converter plugs seem pretty decent but they would be a right pita to take on and off all the time.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
