DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Washing machine in cellar?
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
jojoyay
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 03, 2006 12:45 pm    Post Subject:
Reply with quote Thanks
I am about to buy my first house and am starting to plan the renovation/decorating work. I would like to move the washing machine out of the small kitchen to make more room (possibly for a dishwasher) and relocate it in the cellar. There is currently no plumbing/taps etc in cellar but there is electricity. Any comments on whether this is vaiable? And if so, cost effective? Many thanks!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Jul 03, 2006 1:57 pm    Post Subject:
If the sewer running from your property is higher than the washing machine outlet then you're going to be involved in pumping the waste water away.
There are proprietry solutions to this problem, but you also have the option of pumping away the water and storing it in a rain butt (or rain butts), although you might find that it's against the Water Regulations to distribute the grey water over your garden unless it's been treated first.
Back to top
 Alert Moderators
thedemps
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 30, 2007 7:26 pm    Post Subject:
Pumps
I have a similar problem - the washer in my cellar is plumbed into the surface water drain which has now collapsed and I have nowhere else to put the washing machine.
Anyone recommend a pump system - water would have to travel about 10m and raise about 3m - smaller pipe the better.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue May 01, 2007 12:16 am    Post Subject:
Sanivite.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Tue May 01, 2007 1:41 am    Post Subject:
You could use a pump with a float switch, if you are prepared to empty the washer into a storage tank in the cellar http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101407&ts=83475&id=76169 or http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101407&ts=83596&id=38988
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue May 01, 2007 7:49 am    Post Subject:
That's all very well for clean water, or for rain water and such like, but washing machine output is in Fluid Category 4 or, in some cases (e.g. after nappy washing) Cat 5, so storing the water isn't the most healthy thing to be doing.
Having said that, that's exactly what the Sanivite is doing, but it has the advantage of being specifically designed for this purpose, and, without intending offence, not home made.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Tue May 01, 2007 3:22 pm    Post Subject:
Just offering an alternative.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue May 01, 2007 9:28 pm    Post Subject:
Once again, without intending to be offensive, it isn't really an alternative.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Wed May 02, 2007 7:14 am    Post Subject:
I think that is for jojoyay or demps to decide.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Washing machine drainage in a cellar 4 1340 Fri Jul 23, 2004 11:57 am
Washing machine in cellar 5 480 Fri Jul 21, 2006 6:25 pm
dry run washing machine 4 180 Sat Mar 22, 2008 12:24 pm
zanussi washing machine - stuck programme dial 2 360 Sun Mar 30, 2008 12:57 pm
Washing machine door not opening 2 320 Wed Mar 19, 2008 11:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
