wall hung wc leaks
3 Jul 2006
Just purchased a wall hung wc and frame. After fitting, there was a leak from the wc spigot end of the plastic pan connector.
The problem as I see it is that the spigot has a usable length of just 25cm and I think that this far too short to make a good connection with the rubber seal of the connector.
I have tried three different connectors both rigid and flexible, but still get the slight leakage.
The wc is made in Italy and I wonder if it meets British Standards. Does anyone know if there is a minimum recomended length for the wc spigot?
whistler said:
Just purchased a wall hung wc and frame. wc is made in Italy and I wonder if it meets British Standards.
Hey, it meeta da EU standard whatta you want , decent sanutary wear like when you hada da Empire...isa Il Duce hisa revenge........alla da tima I take da pizza. You could try one of those drainage black rubber sleeves with jubilee clips ;) OR you could ignore me ...many do :LOL:
My first post on this forum ...... and all I get is stupid replies!
Any sensible helpful people on here?
whistler, measure the diameter of the pan spigot.
If it's not in the supported range of size for a standard pan connector, then order (from a decent plumbers' merchant) the correct Multikwik pan connector for that diameter.
Or, after assembling, make an external seal using a good quality mildew resistant sanitary silicone sealant (e.g. Dow Corning 785).
Perhaps your not putting it together properly. :rolleyes: :rolleyes:
Wassa matta you, gotta no respect :LOL: wadda you expect , we doa this for nothing but the warma glow of helping people :rolleyes:
Hey ... Igottaloadsoderespectman. Ialsogottaleakingloo datiwannasortout.
The diameter of the wc spigot is fine at about 95mm. Its the protruding length at 25mm which I think is too short. I have considered using a silicone seal, but it shouldn't really be necessary.
Just found the names of the couplings I was on about .............Flex-Seal.....or ....Fernco......from Drain Center (like Plumb Center,same group).......have a look at Google ;)
:LOL: :LOL:
this forum really rocks :evil:
Mr Crow are you saying I`m as silly as a rook :oops: ;)
That's odd, because at 95mm I'd call it pretty far from being "fine" - I'd call it "disastrously tiny".
Why? 95mm (or 4 inches if you prefer) is a fairly standard diameter isn't it?
