Machine is filling, then a pause the draining.
Cleared obstruction in filter at bottom of machine. Cleaned all pipes. Cleaned brushes.
Still no luck. Machine starts program on display as it should. But just does not turn or spin. Belt is on and ok.
Checked pressure switch. It has 4 pins. Without pressure pins 2 and 4 are the only ones shorted. With pressure, pins 3 and 4 are shorted.
There are 10 pins connected to the motor. These are the readings I got from the resistance wise.
Pins 1,4 & 5 = 1 ohm.
Pins 6 and 7 = 138 ohm.
Pins 9 and 10 = 1265 ohm.
