soil pipe angle to stack
13 Dec 2004
Hi
we are installing a new bathroom and the soil pipe from the wc has a natural place to run through the outside wall. it appears to have been made before we purchased the house.
however this "hole in the wall" is below the floorboard and under joist hight. This gives us a 13inch drop on the pipe from the WC to the external stack. the pipe runs along a wall before exiting and is about 1.4meters long. A second skin is to be built after the pipe is fitted.
is their any problem with having a drop of 13 inch to the stack on a 1.4 meter run of pipe?
Thanks for any help
Andy
shouldnt cause too much of a problem. cant u run pipe under floor and put a bend upto back of pan.
many thanks for the quick responce
unfortunetly i cannot run it under the floor and up as its against the wall in between where anotheter block wall will be built some of which has been built to the first floor and is already above joist hight. A little complecated i know but if the gradient is ok then the easiest way is to run it at the gradient rather than trying to cut some block work out.
thanks
Andy
hi the fall should be 1 in 80 - 1 in 40=16mm to 25mm for every 1m this is because to much fall means the water will not wash the waste away as good as it would be to fast of a flow and leave behind efluent just somthin to consider
hi
thanks for that, I have sorted the problem by cutting the hole in the outside wall to the stack higher up. big hole now; but filled easily with block. this i hope has got me into recommended limits.
Thanks for the help nad insight!!
Andy
