Joined: 09 Jul 2006 Posts: 7 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Sun Jul 09, 2006 8:29 am Post Subject:
22mm hot 15mm cold
I am replacing my bathromm suite, and notice that the hot supply is 22mm and the cold supply is 15mm. the hot is supplied from a cylinder and the cold is direct fed from the mains. is there a specific reason for this difference in the diameters of pipework?
Joined: 04 Oct 2005 Posts: 555 Location: British Virgin Islands Thanked: 0 times
Posted: Sun Jul 09, 2006 8:36 am Post Subject:
Cold will be at a higher pressure than the hot, so can flow higher rates through the same size of pipe. Consequently 15mm pipework will probably be adequate for the cold, though you will have to add a non-return valve to the cold pipe if you use mixer taps anywhere in the bathroom (to prevent backflow)
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Sun Jul 09, 2006 8:41 am Post Subject:
The mains cold is supplied at a much higher pressure than the tank fed hot, so it can overcome greater resistance from the pipework. the flow rate from the cold tap will probably be much better than from the hot, despite the smaller pipe. Mixing hot and cold at very different pressures (in a shower for example) can be problematical and should be avoided.
Joined: 29 Aug 2005 Posts: 455 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 09, 2006 10:11 am Post Subject:
You can use a Trevi Boost venturi shower which works well as long as it fitted within the makers parametres. You can also put an in-line Grunfoss booster pump on the hot and have a pressure equaliser on the hot and cold before the mixer. This will ensure the cold is dropped to the same pressure level as the hot.
Joined: 03 Jul 2006 Posts: 1279 Location: United States of America Thanked: 0 times
Posted: Sun Jul 09, 2006 10:48 am Post Subject:
Re: 22mm hot 15mm cold
The simple answer, if you are unsure, is to leave all pipework well alone & just tie in to it.You do not need to know the why`s & wherefore`s. Just re-install your bathroom exactly how it was originally.
Posted: Sun Jul 09, 2006 1:20 pm Post Subject:
fitz1 wrote:
if its for shower its easier and cheaper to fit a tank fed cold from storage tank.if tank is big enough.
Then you have put in one of those awful twin impellar pumps that whine and shake and take up space. The Grundfos Booster looks like any other Grundfos pump. Cheap too at around £80.
Posted: Sun Jul 09, 2006 1:21 pm Post Subject:
Posted: Mon Jul 10, 2006 12:12 pm Post Subject:
cobblerz wrote:
is the grundfos booster, from the water tank or is it just used as an inline booster for the shower?
The Grundfos is on the hot from the cylinder. Best have it on the shower only if all the other taps are fine.
The cold is from the mains.
The pressure equalizer makes sure the highest pressure is dropped to the lower pressure equalising the hot and cold.
Many mixers already have these inside the mixer, if not it is a extra item costing around £20.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
