I've recently been digging out for foundations to concreate down the side of my house where i've found a gas pipe. No problems in that but there is a vertical pipe with a square bolt on top and it looks like it leads into a chamber or trap. The gas pipe that runs into the house is connected to this trap via a T joint. From the top of the pipe its about 7 inches below the DPC. Since i was going to concrete over this pipe do u think it would be ok to cover it since it was covered up before or call TRANSCO (think they've changed their name now) before i fill it in. Or i thought about using some soil pipe etc to slide over the pipe and put a cover over the end and then cement over it so if they needed to access it they could.
Any suggestions????
Any suggestions????
