DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Noise in new mono bath taps
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
LeeLee25
from United Kingdom
PostPosted: Sun Jul 09, 2006 10:27 pm Reply with quote
Hello, have just installed new mono bath taps. When you move the lever in the centre and have cold and hot water running at the same time, it gets quite noisy!
Cold is mains fed with ok pressure and hot is from a hot water cylinder, pressure not as good but could be down to the cylinder being on the same level.
Not to bothered about the pressure just the noise.
Can anyone help?
Many thanks
LeeLee25
Back to top
 Alert Moderators
Expertboy
from United Kingdom
Thanked: 2 times
PostPosted: Mon Jul 10, 2006 1:06 pm Reply with quote
try turning your mains stop tap down a bit.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Mono Basin Taps - Ceramic Valves Query 2 760 Thu Sep 28, 2006 7:24 pm
mono taps without pop up waste 3 1500 Fri Sep 07, 2007 7:44 pm
Mono taps help please 8 1440 Thu Apr 17, 2008 4:11 pm
Mono-bloc mixer taps? 2 860 Mon Jul 24, 2006 9:36 pm
Mono taps 2 480 Thu Jan 27, 2005 3:36 pm
DIYnot
