DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Air Bricks and Cavity Wall Insulation
This topic originated from the How to page called Wall Insulation
Click here to return to the page called Wall Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Giblets46
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 13, 2004 3:52 pm    Post Subject:
Reply with quote Thanks
Hi, was wondering how sleeves are fitted to air bricks, does the air brick have to be removed in order to fit these? If there is inside ventilation, this can obviously be acheived by taking of the internal fixing, but what about where this is not the case?
Many thanks
Edward
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Jan 13, 2004 8:04 pm    Post Subject:
Not quite sure what you mean ? icon_confused.gif I'm guessing that the sleeves you're talking about,is the fitting for the cavity wall insulation ? icon_confused.gif
Ahhhh,I think I know what you mean now,you're having cavity wall insulation and don't want the foam to blocks the air-brick ? To be honest I don't know much about them and I would've thought the company would deal with it.You might also find the condensation level will increase as the house get warmer ! Apparently the best way is to insulated is on the outside walls.
Hopefully,GwaiLo will be here soon who might know more about this icon_smile.gif
Back to top
 Alert Moderators
GwaiLo
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 13, 2004 10:25 pm    Post Subject:
I presume you are asking about the cavity liner, thats the thing that connects the airbrick in the outer leaf to the airbrick/vent in the inner leaf.
These are proprietary products. They are made in both plastic and terracotta, and quite probably other materials too.
They need to be supported at both ends generally, so it may involve removal of the airbrick. However, it may be possible to fit it from the inside only. The key thing is that it needs to be securely fixed. or it will drop into the cavity.
There may be a bricklayer on here who has actually had to do it, I just design stuff and then critisise the trademen doing the work I'm afraid. icon_wink.gif
__________________
This is not advice. Seek professional advice. I accept no liability errors or omissions.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Air Bricks / Cavity Wall Insulation 2 2300 Wed Aug 30, 2006 12:42 pm
long wall, how many bricks? 3 1460 Thu Jun 19, 2003 1:14 pm
Air Bricks (Again) 5 1160 Sat Oct 18, 2008 12:25 pm
cracked bricks and pointing 3 1920 Sat Oct 12, 2002 10:39 am
Restoring brick fireplace - how to clean bricks?! 4 3280 Mon Jul 24, 2006 5:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
