Joined: 11 Mar 2006 Posts: 569 Location: London, United Kingdom Thanked: 0 times
Posted: Thu Jul 13, 2006 3:31 pm Post Subject:
if you have just had them skimmed only, then you wait till the plaster has dried, it goes a very pale pink, and you can paint with Vinyl matt, or better still super matt that doesnt contain any vinyl.
Dont use silk, or soft sheen if you can help it, till at least a few months down the line.
Do a miscoat first, which is a thinner solution of your paint, all you have to do is thin it down with approx 15-20% percent of water, give a good stir, then paint on the walls.
This seals the walls ready for your good coats, if your using a good quality paint like dulux, I would still thin your second coat, just a little,and then just paint from the tin for your third coat, if you think it looks too thick, then just add a tad more water, cause sometimes the paint can drag if its too thick,and painter not quick enough lol
Diyers are slower than the professional painter, hence you might get the dragging, but if you do one wall at a time and see how you go.
Joined: 13 Jul 2006 Posts: 2 Location: Bedfordshire, United Kingdom Thanked: 0 times
Posted: Sat Jul 15, 2006 8:38 am Post Subject:
A friend suggested sealing the walls with a solution of pva and water, is this any good or is it best just to go with the thinning of the paint ?
Thanks for your advice,
Joined: 19 Jan 2007 Posts: 543 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Fri Aug 03, 2007 8:08 am Post Subject:
So you folks rub down newly plastered walls after applying a mist coat? Is that to smooth the plaster finish or to remove any little bits of paint that haven't been absorbed? Also, doesn't it remove a lot of the mist coat or are we really talking about a very ight rub down?
Joined: 28 Oct 2005 Posts: 10199 Location: United Kingdom Thanked: 57 times
Posted: Fri Aug 03, 2007 8:50 am Post Subject:
Most decorators use a sander on a pole and give a quick wizz over BEFORE the mist coat. The reason is that if the plaster has the odd line on lump it will clear it. If the plaster is dead smooth, then it will give it key.
It's pretty common to give a secondary light sanding before the main coat.
Joined: 23 Jun 2006 Posts: 217 Location: United Kingdom Thanked: 0 times
Posted: Tue Jul 08, 2008 9:38 am Post Subject:
How many coats of the Dulux Supermatt should you apply?
As I understand it, the first coat is the mist coat which you thin with water.
But should the second coat also be the Supermatt stuff, or normal vinyl matt emulsion coloured paint (perhaps thinned with water also for a better finish)?
Yep..first coat is the mist..
You can use ordinary vinyl matt emulsion over the top, providing you give it a second coat of vinyl matt..otherwise you get whats called 'shearing' flashing shiny uneven sheen marks where the roller and brush has overlapped
But if the plaster is deep id suggest to stick with supermatt in case there is still any trapped moisture in the wall...sometimes two coats is enough but three will look better.
Posted: Wed Jul 09, 2008 10:16 am Post Subject:
Thanks Zampa.
Is that the process you'd follow:
supermatt mist coat > sand with 120/180 > vinyl matt 2nd coat > sand with 120/180 > vinyl matt 3rd coat (watering down the paint on each coat to get a better finish).
What I mean is, you've said I can do it this way, but I'd like to know the preferred way - what a pro would do.
Thanks fella.
Give the wall a dry scrape over to remove any cruddy bits of plaster etc..the mist coat (if your using dulux supermatt then you can add about 40% water) rub down and fill the walls where needed , id use 100 grade, 120-180 will clog easily with supermatt...rub down the filler and apply two more thinned coats of you vinyl matt..(thin by about 25% each one..dulux is very thick and dry emulsion..if you feel it 'pulling' or you are getting a lot of 'orange peel' in the emulsion then thin it a little more.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
