I have recently had a Mira Fino EV shower (cost £200ish) installed on a combi boiler system. The boiler we have is a Glow worm Swift flow 80 honeywell - about 13 years old, I think.
When the central heating is on the shower works fine (although the pressure is not as good as we were hoping) but with the heating switched off the shower does not get hot. We have resorted to turning the bath hot tap on , then switching the shower on and then turning the hot tap down to a trickle. this usually maintains a hot flow.
I have taken the shower head off and turned the shower on, this results in a maintained hot flow from the hose.
We bought the shower as it was suitable for a combi boiler.
The pressure gauge on the boiler is around 3 bar.
When we had the boiler serviced we were told we lived in a quite low pressure area.
Have we wasted our money on a more expensive shower when a shower fitted to the bath taps would (maybe?) stay hot and have the same pressure.
Any suggestions would be gratefully received.
