Is it necessary to use tile paint for this job or would gloss paint do just as well, not as many available colours in the tile paint. Or is there any other alternative paint.
As long as you use a tile primer, you should be o.k with a solvent based gloss over the top.
I used Wickes water based Tile Primer and Self Undercoating Crown Solo Satin on top which has turned out a big success.
