Vailant boiler
idy
19 Jul 2006
Bradford
The preasure of the water level seems to come down every two days. The overflow water pipe outside is on the wall is draining water out.
PLEASE HELP
What would you like us to say? No one is going to rush over to you are fix it free! All you will get here is written suggestions.
Either the pressure is too high, over 3 Bar, or the pressure relief valve is leaking.
If its leaking then the obvious solution would be to replace it.
Its probably the thin end of the wedge and the system may be dirty and will need to be cleaned if the job is to be done properly.
Tony
Could be your expansion vessel needs pressurising. If there is insufficient pressure in it, there is nowhere for the hot water to expand. Pressure builds up and releases out of the overflow. Then the water cools down and your system pressure falls. You top it up again and the cycle repeats itself.
