| Author |
Message |
Laburnum
Joined: 06 Feb 2006 Posts: 52 Location: United Kingdom
Posted: Wed Jul 19, 2006 7:32 pm |
Plumbed in a bath today, there appearsed to be no leaks what so ever.
That was until i filled the bath, then emptied it, then a tiny drip appeared under the bath, but 2-3 inches from the waste, there is no damp from this drip back to the waste, so its not a run.
so i thought there must be a hole in the bath, so i filled it again and left the water in, but no drips what so ever. i left this 15 mins and still no sign of a drip. there fore i emptied it and low and behold drip, drip ,drip!
really cannot fathum this out as there is no sign of any hole, and like i say the drip is not near any join or connection...
has anyone come across anything like this, or can anybody shed any light.
bath was from b n q might this be the answer???
cheers |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Bamber gaspipe
Joined: 03 Jul 2006 Posts: 1279 Location: United States of America
Posted: Wed Jul 19, 2006 7:41 pm |
Do as you have done & fill bath. Completely dry beneath bath & where drip was using towel, empty bath. Using coloured toilet paper/kitchen tissue, ( I like pink ),pat around trap,checking tissue after each pat. Do same where drip was spotted. My money is on trap area. |
| Back to top |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Wed Jul 19, 2006 8:10 pm |
Plastic or metal bath?
Not condensation is it?
I preferred the purple loo paper but you don't get it so much. Once joked with a lady about how out of fashion it was then she produced a roll from the cupboard...
If you have kids pinch some chalk and cover all round where you think it might be leaking with a coloured chalk. |
| Back to top |
Bamber gaspipe
| Back to top |
solo
Posted: Wed Jul 19, 2006 9:15 pm |
I always go into the bedroom to dry off. There just isn't enough room under the bath. |
| Back to top |
fitz1
Joined: 24 Nov 2004 Posts: 1983 Location: Merseyside, United Kingdom Thanked: 18 times
Posted: Wed Jul 19, 2006 9:21 pm |
check the overflow plastic flexi pipe. |
| Back to top |
Bamber gaspipe
Posted: Wed Jul 19, 2006 9:46 pm |
| solo wrote: | | I always go into the bedroom to dry off. There just isn't enough room under the bath. |
| Back to top |
grrinc
Joined: 12 Jul 2006 Posts: 279 Location: Hampshire, United Kingdom Thanked: 1 time
Posted: Wed Jul 19, 2006 10:24 pm |
If you have a plastic bath with fibre glass reinforcement, then chances are, when you empty the bath the water gets between the two layers and finally leaks out somewhere like you described.
Take out the waste and refit it but bedding it into a lot of silicone around the actual waste hole area. Some waste snow come with double wrapped washers that eliminate this little problem.
If this doesnt make sense I will post a little picture. |
| Back to top |
Laburnum
Posted: Sat Jul 22, 2006 1:03 pm |
thanks for the responses
think i understand Grrinc, but a piccie would be great...
cheers everyone! |
| Back to top |
squeaky
Joined: 21 May 2006 Posts: 1522 Location: United Kingdom Thanked: 49 times
Posted: Sat Jul 22, 2006 8:04 pm |
If you find its coming from the waste, throw away the useless rubber washer between the inside of the bath and the chrome 'plug ole' and use LSX sealant, available from plumbers merchants. Als try some PTFE tape around the thread. |
| Back to top |
grrinc
| Back to top |
Paul Barker
Joined: 04 Aug 2005 Posts: 8314 Location: Yorkshire, United Kingdom Thanked: 458 times
Posted: Sun Jul 23, 2006 7:28 am |
That makes a lot of sense, I'd not come across the problem but fibreglass without a gel coat does become porous, maybe baths up and down he country are starting to erode away around the waste hole. Manufacturers should put a gel coat on afte they have cut the waste. |
| Back to top |
