Joined: 20 Jul 2006 Posts: 3 Location: India Thanked: 0 times
Posted: Thu Jul 20, 2006 6:35 am Post Subject:
Submersible Cable box
I want 2 use a submersible cable box in fountain having 10-12 nos. 230/12V Transformer in it and having incoming and outgoing wires from it. pls tell me wat provision i hv 2 made for this. its urgent. thanx.
___________________________________
lynda, moderator, moved as posted in wrong forum
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Thu Jul 20, 2006 4:34 pm Post Subject:
you can get IP68 glands and enclosures but unless there is no other real option (say a fountain cluster in a big lake) i'd seriously advise not doing this.
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Thu Jul 20, 2006 7:59 pm Post Subject:
the simple answer is you can't do as you suggest
if the box were water tight it would develop condensation, ruining your transformers, to resin fill them is a good idea in theory, but that would still leave a cavity around each transformer. (and if it didnt the trasformers may overheat) best option dig deep get submersible transformers made for the job
__________________ Do you like music Mr Finch?
Forum = Opinions
Posted: Thu Jul 20, 2006 11:37 pm Post Subject:
if the box is truely watertight (which may admittely be difficult to achive) then once the initial damp is removed by the silica gel no more should get in.
Joined: 06 Jul 2006 Posts: 99 Location: Devon, United Kingdom Thanked: 0 times
Posted: Sat Jul 22, 2006 2:51 pm Post Subject:
There is several options, i would extend the cables and fit the transformers above the water line. i would expect the transformers will be ok if fitted in a resin sealed joint kit the water will keep them cool but one big enough is going to get expensive.
simple primitive solutions,
fit the transformers in a "diving bell" type enclosure, that is a bucket turned upside down. The air pocket will stop the water getting in!
Fit the transformers in a IP68 enclosure and hope for the best!
One thing i have seen done to great effect is pressurise the enclosure with air (using a fish tank air pump) that keeps the water out but condensation can be an issue unless there is adequate heat to stop it forming.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
