DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
consumer etc etc
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
umuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 22, 2006 11:41 am    Post Subject:
consumer etc etc
Reply with quote Thanks
hi all,
i have just fitted a new cunsumer unit within the house that runs the usual stuff,
only thing is they have outbuildings. now they have 2 x incoming swa cables next to this new unit i have fitted, 1 x 2 core and earth 1 x 3 core & earthe,
these are running fridges etc due to them usng outbuildings as a catering company,
i persdonaly dont think id get away with connectig thee via the new unit,
would i be better off fitting a separate unit to bring these into, ? i know both out buildins have their own units, fuses, etc so was thinking just getting a main switch and say using 50 or 63 amp mcbs.....
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Jul 22, 2006 11:49 am    Post Subject:
What sort of current pull are you talking about from the outbuildings? The problems with using MCBs can be the very low efli values required for the 0.1s disconnection. What type of supply do you have, PME / TN-S? I take it you are talking single phase? Can you show us a picture of the setup, you say SWA and then say 2core and earth? As it is a house I take it you know about Part P England/Wales.
Back to top
 Alert Moderators
umuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 22, 2006 1:21 pm    Post Subject:
sorry i meant swa 3 & 4 core, the 4core was connected to 2 x 45 amp , fuses to start with, the 3 core was hard wired to the main switch on the house consumer, and yes single phase,
earth is pme, ( not done by me but someone who had been before and just stuck a 16mm earth into the n side of the incomer,
not that sure what current the out buildings are pulling tbh, the cooker etc is gas so nothing from that, mainly just chest freezers, fridges, ligting,
in all fairness the house need re-wiring but as he see's it its to much hard work or shouldi say to expensive lol,
all i have done at present at his request is fitted a 10 way split load board , 2 ring mains, 2 lighting circuits, electric gates, emersion, etc,
he has had an extension which will see another ring main going in, lights where just added to existing circuit as im told,
my main concern was just the out buildings really, he is a friend and its just a favour im doing him, i am aware of part p but as you are probably aware most sparks wont do a minor works certy etc unless they have carried out the work,
and a periodic inspection is out the question as does not have a chance of passing that lol,
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Jul 22, 2006 1:30 pm    Post Subject:
Are you related to Mr Walker?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Jul 22, 2006 1:33 pm    Post Subject:
if the outbuildings are for commercial use, they should be metered seperately. From what you say, if he keeps them on the same supply, said supply really ought to be 3phase icon_eek.gif
Back to top
 Alert Moderators
umuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 22, 2006 2:14 pm    Post Subject:
not really commercial use as such, they make food for parties and stuff, 3 phase would be nice but again cost etc,
mr walker ? who is he,
can anyone offer a safe option with what i have, ? apart from the above and obvious costly solution, he has been running things as they have been for years,
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Jul 22, 2006 3:53 pm    Post Subject:
A starter would be to find out the loading requirements for the install and the size of the SWA. Are there any extraneous conductive parts in the outbuildings? Replacing a CU requires an EIC. Some stuff on Part P:
Ban-all-Sheds part p summary 04/06
Guidance to approved document P
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jul 22, 2006 4:41 pm    Post Subject:
Agree with Spark123,
You need to find out the loading of these outer buidlings to see if the size of the cables are sufficiant for the design current, voltdrop and satisfying dissconnection times as per BS7671.
RMS
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Jul 22, 2006 8:55 pm    Post Subject:
And if the outbuildings are for commercial use, are you qualified to work on such premises? Why are you asking questions you should know the answers to on a DIY forum?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
umuk
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 24, 2006 2:30 pm    Post Subject:
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Jul 24, 2006 7:46 pm    Post Subject:
umuk wrote:
to help DIYers. DIY is not something that should be undertaken in commerical premises. And you must be a DIYer to ask questions like you did in the first post.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Moving a consumer unit 8 520 Wed Jan 02, 2008 7:15 pm
A Rare Consumer Unit?? 7 683 Thu Jan 03, 2008 3:57 pm
Consumer Unit Change - NICEIC Assessment 7 880 Fri Jan 04, 2008 7:14 pm
Electrician-fitted part-load consumer unit. 11 700 Wed Jan 02, 2008 3:01 pm
Part P and Consumer 44 2620 Fri Dec 28, 2007 9:17 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
