Joined: 24 Jul 2006 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Mon Jul 24, 2006 12:32 pm Post Subject:
Overflow Dripping
Hi
The overflow on the side of the house (about 9ft up) is permanently dripping at the moment and it seems to be full of water.
I thought the shower might be blocked (don't ask why!) so I stuck some heavy duty cleaner down it - this seemed to stop the dripping - so I thought - I've checked today and it seems to be dripping again!
Another problem seems to be when we use the shower head on the bathroom taps - once finished - water gushes out of the same overflow pipe.
All a bit of a nightmare really.
Any idea?
I think I have a problem with blockages and pressure - what do you think?
Joined: 05 Jul 2006 Posts: 971 Location: London, United Kingdom Thanked: 2 times
Posted: Mon Jul 24, 2006 3:52 pm Post Subject:
You obviously know very little about plumbing.
Have a look in your loft and you will see that your cold water tank is overflowing this may be due to your inlet ball valve not functioning closing off the incoming mains feed.
The reason the overflow stops/slows down when you use the shower/taps is beacuse you are draining it down faster than it is filling up.
Call a plumber to get it sorted soon especially if you are on a water meter.
Pete
Posted: Wed Jul 26, 2006 1:19 pm Post Subject:
Thanks for the info Fluffstar - and thanks for rubbing it in about not knowing anything about plumbing!
Been up into the loft - (yes I do know what that is at least) checked out what you suggested and it is okay - it is shutting off.
I've checked the upstairs loos and they are not overflowing.
It did seem to start when the Misses cleaned the rubbish that collects in the plug hole the on-suite shower. All the stuff collects in a filter - this was disposed off - but some of the rubbish collects below the filter - this was not disposed off and was washed down when we used the shower again. Could this have bunged up the pipes - or am I clutching at straws!
Joined: 28 Jan 2005 Posts: 127 Location: United Kingdom Thanked: 0 times
Posted: Wed Jul 26, 2006 2:17 pm Post Subject:
First question is what is this "overflow" attached to? If It's only 9ft up on the side of the house it seems a bit low for an overflow on a tank in the loft? Sound more like a wc overflow or combined HW tank overflow.
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Thu Jul 27, 2006 7:17 pm Post Subject:
Re: Overflow Dripping
Not so easy....
wellhard1 wrote:
...Another problem seems to be when we use the shower head on the bathroom taps - once finished - water gushes out of the same overflow pipe.
Do you have mains pressure feeding the cold bath tap? If so, when you use the shower attachment it may force it's way back up the hot pipe and cause the cold feed tank to overflow.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
