MrGorsky
Joined: 24 Jul 2006 Posts: 4 Location: London, United Kingdom Thanked: 0 times
Posted: Mon Jul 24, 2006 9:32 pm Post Subject: Fitting A New Staircase - DIY |
Is it possible to fit a replacement staircase without knocking down a wall in my stairwell? I was hoping I could build my (flatpack) stairs "in situ" but I have been told I'll have to get a builder to come and knock down a wall, so I can fit the new stairs before he/she builds it back up again. Is this my only option? |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Tue Jul 25, 2006 6:50 am Post Subject: |
Never come across this, I've fitted many stairscase without having to knock down wall. I can't see your layout though, a photo would help. __________________ Always judge a man by the way he treats someone who is of no use to him |
MrGorsky
Posted: Wed Jul 26, 2006 1:27 pm Post Subject: |
I own a two bed victorian terranced house.
The stairs run paralell with the front of the house up between the front room and the back room. At the top of the stairs you turn either left or right and walk straight into one of the two bedrooms.
I want to turn the stairs in the opposite direction, and then build a corridor into the back bedroom so that we can get to the bathroom without having to go through a bedroom.
As I said before, I've been told I'll have to knock a wall down to get the staircase in, when I was hoping I'd be able to remove the old stairs, and then fit my new strings to the landing and the floor, and then fit the treads and risers to the strings.
I'm being told that the stairs will have to be assembled before I fit them, and to fit them I'll have to knock a wall down due to lack of room. |
masona
Posted: Wed Jul 26, 2006 4:54 pm Post Subject: |
Normally it's only the strings, risers & tread are fitted together then assembly on site with newal post, top & bottom riser etc
Although you can cut the staircase in half to join them again but the cut must be done correctly. __________________ Always judge a man by the way he treats someone who is of no use to him |
jddevel
Joined: 29 Jul 2006 Posts: 19 Location: United Kingdom Thanked: 2 times
Posted: Sat Jul 29, 2006 5:23 pm Post Subject: Fitting new stairs |
Stairs made the traditional way can normally quite easily be fitted insitu. It is normally necessary to fit first couple of risers and treads into strings which assuming completely closed area have been placed in position against the walls either side of stair well. Raise or prop both strings up off the floor level. Glue and wedge the first couple and possibly the top couple of risers and treads in place plus supporting blocks. Making sure all obviously is square as you go. Once this has been achieved move the strings back into place and complete fitting remainder of treads and risers. If no access under stairs to complete fitting obviously leave lowering into place until all fixed. Climb out from under stairs on to top landing and the lower completed stairs into place. Stairs obviously should not be that tight that a certain amount of side ways adjustment cannot be made. Fix strings to side walls and make good. Hope this helps. |
bodgeitbob
Joined: 30 Jun 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sat Jun 30, 2007 8:40 pm Post Subject: Turning a set of stairs |
My son has bought a house that sounds similar to MrGorsky I was wondering if he had any luck changing the direction?? |
