Tracing air leaks
17 Jan 2004
Gathering air in three radiators on third floor. All downstairs rads Ok and header tank is full. Obviously drawing in air ahead of or in first radiator. Any tips for tracing the leak?
It might not be a leak, and it might not be air. Turn a container upside down over a bleed valve and let the gas out so it can collect in the container. Then light it, if it pops, it's hydrogen. If so it's corrosion that's causing the problem.
to oilman
thanks for that - more to worry about!
Is that like setting light to a f**t ??? ;)
Don't be silly oilman he means those nasty little italian cars.
Scoby,can you use the spell check next time,you're making hard for us to understand.
I think he means "I suffering from cold feet".
