Potterton Profile 60e - fan runs but won't light
29 Jul 2006
Surrey
Hi there
Moved into a new house two weeks ago, heating & hot water working fine until yesterday. Yesterday morning there was no hot water, checked the boiler and it didn't seem to be doing anything.
Having searched these forums I found the boiler's reset switch and pressed it. Now the fan operates, but there still seems to be no attempt at lighting.
Two factors that might possibly have affected it:
1 - the thunderstorms, wind and torrential rain on Thursday
2 - Plumbers have just finished installing a toilet in what used to be the downstairs cupboard, although I can't really see how this could have affected the boiler.
All suggestions gratefully received!
Thanks.
James
Arfur mo, are you saying that you did reset the boiler with that switch? Did it definitely click in? If so it had overheated. They're normally rather loose buttons, it's obvious when you're actually doing something when they've popped out.
If it did overheat you need to find out why, but that wouldn't stop it lighting once reset.
If you didn;t need to reset it, it either needs a service, or one of a couple of common parts has "gone" - aps and pcb's fail on those.
Thanks for the reply, Chris
The reset button had definitely popped out, and I definitely pressid it back in again, so it sounds like time to call in the pro's ...
Cheers
James
Check there's water in the header tank, and, more likely fault, that the pump's running.
Still should light and overheat again though...!
if the fan's operating, then there is nothing to stop it going through the sequence
if the fan comes on, you have to find if it's operating the pressure switch, if it is, it should spark to ignite the pilot
does it do this ?
Hi, thanks for your reply
It's definitely not making any attempt at sparking. Sorry to sound ignorant, but where is the pressure switch and how do I check that it is operating correctly?
Thanks in advance
James
INstructions are at partsarena.com/baxi
You need a multimeter
If my memory serves me right i believe this boiler is on a positive fan flue so dont attempt to go in the comb chamber or you may get very high co levels produced
James
The air pressure switch is basically a microswitch which is operated by the pressure difference across a membrane
You need to check the resistance of the microswitch in the normally open position , you also need to check that it is mocving from the normally closed to the normally open position when the fan operates. For this you will need a multimeter, do you have one ?
If it checks out OK< then the problem must lie with the pcb, as otherwise you would hear the spark
just a sugestion, you say you`ve had a load of rain ? does the flue point slightly upwards ?, one of my customers moved in to a new house last year & rang me with the same prob.
Water had got inside the flue & in to the press. switch via the venturi & down the rubber tube. If you can locate the press. switch try pulling each tube off in turn & look for sighns of water . DON`T FORGET TO TURN POWER OFF FIRST
