andrewh
Joined: 23 Apr 2006 Posts: 9 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Mon Jul 31, 2006 5:22 pm Post Subject: laminate flooring |
how do you go around the door frames with laminate flooring and still keep the expansion gap |
gcol
Joined: 22 Sep 2005 Posts: 6580 Location: Lancashire, United Kingdom Thanked: 12 times
Posted: Mon Jul 31, 2006 8:32 pm Post Subject: |
There should be instuctions on the laminate. But anyway, you need to lay the underlay and a piece of laminate (upside down) near the door case, then using a saw (flat to the laminate) cut the bottom of the door casing away. Then you need to cut the laminate so that you can fit it under that cut out.
When that's not possible, just cut it as close as possible and run a bead of decorators caulk around the edge. |
big-all
Joined: 12 Jul 2004 Posts: 5769 Location: Surrey, United Kingdom Thanked: 24 times
