Can anyone please help!!!
I have a Honeywell Plan Y system - V4073A Mid Pos Valve, T6060B Room Stat and L641A Boiler Stat with Potterton EP2002 Controller and Glowworm Mk II Boiler.
The room stat isnt controlling the boiler, mis position valve or pump?
The switched live on the room stat (supplied by controller) looks ok, as does the operation of the room stat (i.e switching power correctly). Whoever originally installed the system has used various types of cable / junction boxes and I cant work out how it is wired.
Where does the output of the room stat then go? (I had some building work done in the locale of the room stat recently and suspect the wiring may have been damaged)
I'm an Electronic Engineer and so will be able to sort it if I have an idea of the wiring schematic.
Many thanks for any help you can offer.
Cheers,
Andy
Cheers,
Andy
