DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wall lights & earth
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
sammy66
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 6:05 am    Post Subject:
Wall lights & earth
Reply with quote Thanks
Hi, Want to replace my wall lights. One side of the room is fne with three cables as expected, but the other side only has 2, ie no earth. Wall light instructions say the lights must be earthed. Is this an expensive rewiring job or easy for a pro? Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mo2
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 12:02 pm    Post Subject:
do you mean 3 cores or three cables, because if there are three cables at one point with three cores and two cables at another point with 3 cores, then that is OK, do you know how to connect them up?
Back to top
 Alert Moderators
sammy66
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 12:50 pm    Post Subject:
Wall lights & earth
Thanks for replying. I mean the existing lights on one wall have only two wires, blue & brown (live & neutral) and no earth that I can see. The new wall light has two cables, one contains live & neutral, the other is the earth so not sure if it's safe to connect the live & neutral ones and leave the earth.
Back to top
 Alert Moderators
mo2
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 1:51 pm    Post Subject:
have you stripped the cable, because the earth will be bare - copper colour whereas the live and neutral will be brown/blue or red/black
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Tue Aug 01, 2006 1:56 pm    Post Subject:
It is not safe to connect the lights without an earth. It's sounding a little bit odd, has someone used 2core flex?
Back to top
 Alert Moderators
sammy66
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 5:50 pm    Post Subject:
Wall light & earth
Have looked again very closely at lights. Existing lights are connected to wall cable via plastic choc box with brown/blue wires & definitely no earth. From the wall there is however a single cable with red and black cores plus a very short bent over copper(?) wire - presume this is therefore the earth but not currently connected to lights? Thanks again for responses.
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 01, 2006 5:56 pm    Post Subject:
This short piece of "bent over copper" will be the earth wire but you still need to ensure that this wire is actually connected to earth.
IMO if the person originally terminated the existing light in this way then other parts of the wiring feeding the lights will need to be checked/tested.
Back to top
 Alert Moderators
sammy66
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 01, 2006 6:27 pm    Post Subject:
Wall light & earth
Thanks for all your responses. Will get a pro in to check.
Back to top
 Alert Moderators
danp
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 27, 2006 3:13 pm    Post Subject:
When did the lighting circuits typically get earth ? (i.e. in the building regs)
I have a 1966 flat and the same issue, wall (and ceiling lights) do not have earth...but all the light fittings I just bought say they need earthing.
Can I earth them to the metal plates behind ? (as someone seems to have done with some of the existing ones)
OR
Do I have to re-wire all the lighting circuits ?
OR
Can I buy lights that don't need earthing ?
OR
any other suggestions pls ?!
Thanks ! Dan
Back to top
 Alert Moderators
sammy66
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 27, 2006 3:36 pm    Post Subject:
We got a pro in to check ours and found out that the earths at the wall lights were not actually attached at the other end, so had to get the earths properly attached but not a long job for the pro.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Question Re: Class 1 wall lights/no earth wire 2 360 Sun Oct 12, 2008 3:12 pm
Non earth wall lights 3 320 Mon Jan 29, 2007 8:56 pm
Earth Has no Sheath - From Wall to Cooker - Is this ok? 7 660 Thu Mar 24, 2005 10:18 pm
Bathroom wall light connection - earth loop problem 4 540 Sun Nov 11, 2007 3:04 pm
Installing new wall lights 9 560 Tue Jan 16, 2007 10:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
