I've installed a wooden floor in the downstairs bathroom and now need to re-fit the toilet.
The floor level has been raised by 40mm and the water inlet pipe is now in the way of where the pan connector will go. I need to move this pipe but the difficulty is that it comes out of the wall (dry lined) has a drain point and then rises to an isolation valve which connects directly to the plastic cistern inlet (20mm thread?).
I was thinking about cutting an hole into the plasterboard, cutting the pipe back clear of where the pan connector will go and then fitting a compression elbow to enable the pipe to exit the wall at a more suitable location.
To make it easier for me (never done any plumbing before), I was thinking about using a flexible tap connector (with isolation valve to connect between the pipe and the plastic inlet. Would this be okay? I don't think I wood need a drain point as the flexible connector would enable me to drain at a low point.
If the above is okay, what flexible connector would I need? It would need to connect to 15mm copper and 20mm (ish) plastic inlet?
Any confirmation that the above is okay or what is the best approach would be much appreciated. I've been putting doing the job off but the missus is now on to me about it!
Many thanks,
Damian
Many thanks,
Damian
